Minimum lift lobby floor area. | Forum
Arkidea Mar 19 '25
In Malaysia, the minimum lift lobby floor area is 5.57 square meters, and the lobby width must be at least twice the car depth.
Here's a more detailed breakdown:
  • Minimum Floor Area:The lift lobby must have a floor area of not less than 5.57 square meters.
  • Lobby Width:The width of the lift lobby should be at least twice the depth of the lift car.
  • Fire Escape Bed Lift:The entry into the fire escape bed lift and exit staircase shall be through a common protected lobby, and the fire escape bed lift shall have a minimum clear platform size of 2.7 metres (depth) by 1.8 metres (width).
  • Pressurized Lift Lobbies:Pressurized lift lobbies are required if the building has a height of 45 meters according to Section 197 of UBBL 1984.
  • Fire Lift Requirements:
    • Lift Speed: The lift speed shall be such that it will run its full travel distance in not more than 1 minute.
    • Lift landing doors need to be fire doors.
  • Evacuation lifts requirements:
    • The minimum dimensions of an evacuation lift should be 1400mm deep by 1100mm wide with a 900mm door opening width.
Arkidea Mar 24 '25
What is considered a budget hotel? What is the meaning / definition of Budget Hotel? A hotel that provides minimum amenities and services for a lower price than a regular hotel in the area. This type of hotel provides clean rooms that are safe and meet the basic needs of a guest. Extra amenities may be available, but for an extra cost.
Arkidea Mar 24 '25
What are the characteristics of a budget hotel? While luxury hotels often provide a wide array of upscale features, such as gourmet dining, spas, and extensive leisure facilities, budget hotels focus on providing essential amenities like comfortable beds, clean bathrooms, Wi-Fi access, and complimentary breakfast.
